Timex 1440 Nylon watch Logo
Posted on Mar 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hi, How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock? It seems to have put itself into military time one day out of the blue, and I can't find a way to get it back. Thanks!
  • 3 more comments
  • Anonymous Mar 13, 2014
    how to get it off military time
  • Anonymous Mar 14, 2014
    set time on timex wr50m
  • Anonymous Mar 22, 2014
    Change military time back to normal setting
  • MiM Hmr
    MiM Hmr Jun 03, 2021
    Worked great on my timed WR50M
  • Anonymous Jul 25, 2021
    For a WR50M, just tap the set button. That cycles it between am/pm and 24 hour modes.
Barbara Phillips
Level 2:
  • Expert 29 Answers
  • Posted on Mar 12, 2008
Barbara Phillips
Expert
Level 2:
Answers
29
Questions
0
Helped
143531
Points
209
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
  • cmyers766 Aug 04, 2011
    How do I can the time on a 12 hour watch, my watch is 1hour slow. not change from daylight saving time
Greg
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 29, 2018
Greg
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
19657
Points
This happened to me. I was pretty frustrated because I have bought many Timex watches and never had this issue. I stumbled onto the answer. Tap the set button and you should toggle between 12 hr and 24 hr settings. I did not find it at first bc I kept holding down the set button to find the option within the mode options as found in other Timex watches.
  • Anonymous Oct 12, 2019
    jesus christ i was messing around with that watch for a week and finally found YOUR answer. THANK YOOOOOOOOO!!!
  • Andrea Belisle Hood
    Andrea Belisle Hood Oct 15, 2020
    Wow. Thank you. Thats way easier than the other answers haha. Thanks for sacrificing weeks of frustration for the rest of us.
MiM Hmr
Level 1:
  • Posted on Jun 03, 2021
MiM Hmr
Contributor
Level 1:
Answers
Questions
0
Helped
19657
Points
How can I change Alexa on my Amazon Echo show to 24 hour time.
Question edited for clarity and toss in some CAPS.
Military Time is 24 hour Time, 00:00 to 23:99! It sounds like actually want 12 hour time, 12 hours of A.M. and 12 hours of P.M.
You just ask :>D
Say "Change to 24-Hour clock" or use the Alexa app.
  1. Open the Alexa app .
  2. Select Devices .
  3. Go to Echo & Alexa, or to All Devices.
  4. Select your Echo Dot with clock device. This opens device settings.
  5. Under General, select LED Display.
  6. Turn 24-Hour Clock on or off.
Change the Time Format on Your Echo Dot with clock
1helpful
How do reset a shake n wake to 24 hour time
SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
4helpful
2answers
How to change a timex wr50m from military time to regular time
in the setting after you have set the date, you have to choose whether 12 or 24. choose 12.
Jul 14, 2011 • Watches
1helpful
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
3helpful
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
4helpful
How do I get the watch to change from military
Get manual here from my tips and tricks.
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Time confusion
Possibly you can change it back by pushing the hour-setting button through a 24 hour cycle--you can see if you are on military time during the PM part of setting it. If it's on military, just keep pushing till you start over at 12 am again (hint: that's 0:00 in military.) At least, that's how it is on my watch.
26helpful
5answers
Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
