THE WASHER WILL WASH BUT IT SEEMS AT THE SPIN CYCLE IT WILL STOP AND BEEP E70. ALSO WHEN I OPEN THE WASHER THE CLOTHES IN IT ARE STILL SOAKED. WHAT DO I DO
I am having the same problem and it never stops. What do I do? The E70 ERROR SIGN.I am having the same problem and it never stops. What do I do? The E70 ERROR SIGN.
I've had my washer for 4 months. This is the first time I have gotten the E70. My clothes are soaked, but appear to be clean and rinsed. I ran just a drain and spin and it seems to be OK. I am wondering if my hoses are connected wrong because the clothes are always very warm to the touch at the end of every wash. I've had my washer for 4 months. This is the first time I have gotten the E70. My clothes are soaked, but appear to be clean and rinsed. I ran just a drain and spin and it seems to be OK. I am wondering if my hoses are connected wrong because the clothes are always very warm to the touch at the end of every wash.
AnonymousMar 12, 2014
was unconnected and reconnected. got part way thru normal cycle, started beeping, shows E70 error codewas unconnected and reconnected. got part way thru normal cycle, started beeping, shows E70 error code
You can't post conmments that contain an email address.
Great news that worked!! I had other issues with my washer and had a repair man come and fix it, when he left I started washing and that's when the E70 showed up uhh he hooked the hoses up wrong.. Thanks a bunch
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets 1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems. 1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open. 2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct. 3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart. 4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door. 5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart. 7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem. 15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine. 15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hi, The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.Hope this solution will fix your problem for sure. Thank You !!
E70 Means that the Hot and Cold water lines are backwards. Switch the lines and cancel out the cycle. Turn the dial to drain and spin and pump all the water out of the unit. Then restart the cycle and it should be fine.
May 15, 2009 Hello, I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
I START MY WASHER AND BY THE TIME THE SPIN CYCLE COMES IT IS BEEPING E70
washer beeps E70 right before the spin cycle.
