He is right, just get a new AC adapter that will resolve your problem
for hp pavilion dv7 laptop ac adapter or you can also get a car charger for hp dv7 laptop
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
SOURCE: I have a HP dv7 laptop it does not work with the
You most likely have a short in the AC adapter and I would replace it right away. I have had my dv 7 for a little over a year and had to replace mine 3 times so far.
Your DC connector is loose from the system board:
Problem symptoms:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
