Question about As Seen On TV Magic Bullet Food Processor
My magic bullet won't press down. It stays stuck and I cannot get the cup to push down onto the turning mechanism that is totally intact. It seems the side 3 pieces will not move downward when the cup is put on it.
    New Friend:
Had the same problem - it wouldn't press down. The little white plastic things inside of the base that go up and down when the cup is pushed down, were stuck. I think that something leaked into them so they wouldn't slide easily. I wiped out the inside of the base with a damp cloth and then I put a drop or two of WD40 at the top of the white plastic pieces and rubbed it up and down the length of all 3 of the white plastic pieces (this being done with the base lying on its side so the WD40 doesn't drip down into the mechanism). Then, with base upright, I used a screwdriver to try to manually push the white plastic pieces down. It worked. Of course before doing any of this - be sure the thing is unplugged (duh!).
Posted on Jun 18, 2012
    New Friend:
What I did was I got a screwdriver and manually pushed the white tabs down and it worked! they loosened up and I could use the nutribullet. I thought this was the easiest solution.
Posted on May 06, 2014
    New Friend:
The reason it gets sticky is because the lid of the cup was not fully tightened and leaked fluid down into the switch mechanism which then dried and caused the white plastic sliders to stick. The quick fix is to lay the base on it's side and using a cloth saturated in hot water to saturate the sliders and its track to loosen the gunk that is making it sticky, while it is wet use a quick spray of WD40 to lube the slider, the WD40 will displace the water leaving a lubricating film. After my warranty expires I will disassemble the base and clean and lube it'
Posted on Oct 24, 2014
    New Friend:
I tried a few of many of the helpful suggestions, so I go and retrieve my Nutri Bullet out of the trash b/c I was fed up with trying to get my cup off that has been stuck for 3 days. First after bringing it back inside, it was in a grocery store bag so it wasn't ucky...I laid it on my heating vent on the floor and left it there for abt 30-40 mins. The cup came off with ease, so I proceeded to clean and unstick all the areas I could, I found a plastic tip from one of my cups wedged in one of the white rubber thingy's...I removed it...oiled the 3 white thingy's and cleaned with a hot dish towel..prepped my cup...put it back to the unit...pressed down on every side and the blasted thing still didn't work. So I'm thinking my Nutri Bullet has made its last smoothie and back to the trash it goes. Thank you for all the suggestions b/c I did get my cup unstuck. I feel better that I didn't give up without giving a good try.
Posted on Feb 11, 2019
    New Friend:
I got a fork and held the little white things down and used a srewdriver to push the little broken bits of cup out. It works again now.
I have brought a cheap drink bottle blender as a back up, just in case it doesn't last.
Posted on Feb 05, 2014
  • 139 Answers
My guess is that the 3 small ear-like stoppers was chipped off from the cup. You should be able to pick it out from the 3 switches with something sharp and use another cup.
Posted on Apr 11, 2010
  • dinky-do29 Jul 19, 2011
    Hey, I just un-stuck my Magic Bullet! Motor was seized, so I took off the bottom (4 phillips screws), turned the straight-slot screw(?) in the middle of the motor to the left and right. It "gave," then I was able to turn the rotor freely left and right. When I put a container on and ran the motor continuously for a few minutes, there was some plastic-like stuff in the container cavity. Looks like it came from under the center spindle assembly. Runs great now. Hope that helps.
6ya staff
SOURCE:
Can I get replacement jars for my Bullet
You can Linda
  • magic bullet replacement parts ' eBay www.ebay.ca > Search > magic bullet replacement parts Find great deals on eBay for magic bullet replacement parts and magic bullet ... 1 Cross Blade Assemly with Seal Ring Gasket For Magic Bullet Replacement Part. C ...
  • Magic Bullet Cups and Lids ' eBay www.ebay.ca > Search > Magic Bullet Cups and Lids Magic Bullet Replacement Cups Blade Juicer Strainer Pusher Pitcher Lids . ... 19 Magic Bullet Replacement Parts 8 Jars Various Sizes 5 lids 4 Rings Strainer .
  • Magic Bullet Blender Cross Replacement Blade w ... - eBay www.ebay.ca > Search > Magic Bullet Blender Cross Replacement Blade w Gasket Find best value and selection for your Magic Bullet Blender Cross Replacement Blade w ... MAGIC BULLET Extractor Cross ... Magic Bullet Replacement Parts Tall ...
  • Magic Bullet Replacement Parts ' eBay 2q== www.ebay.com/bhp/magic-bullet-replacement-parts Find great deals on eBay for Magic Bullet Replacement Parts in Blenders ... you can find Magic Bullet replacement parts, including the Magic Bullet ...
  • Canadian Tire Magic Bullet Magic Bullet Single Shot, 12-pc ... answers.canadiantire.ca > ... > Kitchen Q & A > Small Appliances Q & A Canadian Tire customers questions and answers for Magic Bullet Magic Bullet Single ... Is there anywhere in Canada where you can buy/order replacement blades? (see ...
  • Amazon.com: nutribullet replacement jar www.amazon.com > Search > nutribullet replacement jar ... nutribullet replacement jar. Just 6 days until Prime Day! Amazon Try Prime All Go. Departments. Hello. Sign in Your Account Sign in Your Account ... by Nutri Bullet.
  • 2x Magic Bullet Flip Top Lids Replacement Part Original ... https://www.amazon.ca/Magic-Bullet-Flip-Replacement-Original/dp/B... 2x Magic Bullet Flip Top Lids Replacement Part Original Fits all Mugs ... YESURPRISE Replacement Seal Lid for Magic Bullet Blender ... Ball Jar Crystal Jelly Jars ...
  • Homemade Magic Bullet: Using a Mason Jar with Your Blender www.primermagazine.com/2011/learn/homemade-magic-bullet-using-a... Video embedded · Homemade Magic Bullet: Using a Mason Jar with Your Blender ... For $.79 each I picked up a bunch of mason jars and now have an easy ... Homemade Magic Bullet...
  • Replacement jar for Magic Bullet? ' Yahoo Answers ph.answers.yahoo.com > ... > Other - Electronics > Next
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2009-07-23 · Anyone successful at buying replacement jars for the Magic Bullet blender? No luck @ www.buythebullet.com or by phone to customer services. No ...
  • Magic Bullet Blenders and Accessories ' eBay www.ebay.com/bhp/magic-bullet Find great deals on eBay for Magic Bullet ... Cook in style with eBay's huge selection of Magic Bullets, ... What you receive:2 Magic Bullet Replacement Tall ...
  • Aug 10, 2016 | Food Processors
    My Magic Bullet will not start or run. it does not twist in the base. How can I fix that?
    Sounds like the white plastic sliders that turn the motor on and off may be stuck. The sliders engage the 3 tabs on the mixer cup which the push down and turn the motor on. Probably have some leakage from the mixing cup gumming the white sliders up. Unplug the mixer from power and use a cloth or sponge fairly wet with some hot water to try and loosen up the stuff under the sliders. Then spritz the sliders with some WD-40 which will displace the water. Dry it off good with a paper towel, let it dry/drain well upside down on a paper towel before you plug it back in. Good luck.
    Dec 13, 2014 | As Seen On TV Magic Bullet Food Processor
    How do I release lock mode on majic bullet?
    Push down and twist.
    https://www.nutribullet.com/customer-service.html
    May 04, 2014 | As Seen On TV Magic Bullet Food Processor
    NUTRI BULLET CUP WONT PRESS DOWN
    I PUT MY FRUIT IN IT AND IT WIZZED FOR LIKE 2 SEC BEFORE IT CUT OUT AND NOW I CANT GET IT TO WORK PLS HELP
    Jan 25, 2014 | As Seen On TV Magic Bullet Food Processor
    I can not get the magic bullet container to lock into the motor, so the motor will not run
    You need to buy a new cup or a refurbished one. Search google with keywords "amazon magic bullet cup".
    May 09, 2010 | As Seen On TV Magic Bullet Food Processor
    Blade is broken can i get new blade
    On the website they are offering a package where you can get a new blade, but it comes with a bunch of other things. The website is: http://www.buythebullet.com/
    and this is the package they offer:
    Deluxe Upgrade Kit Upgrade your Magic Bullet! You can save even more time and trouble in the kitchen with the Magic Bullet Deluxe package, which includes 2 additional Tall Bullet Cups and 1 additional Short Bullet Cup, plus 3 more Stay-Fresh Re-sealable Lids.
    Using the Magic Bullet in our own homes we've found these extra Bullet Cups and Lids come in very handy when the others are being used to store leftovers in the fridge. Plus, you also get 1 extra Cross Blade. And since this is the blade you'll use the most, it's nice to have an extra one around when the other is in the dishwasher. If you have a family at home, the Magic Bullet Deluxe is a must! Upgrade your Magic Bullet today for just one payment of $29.97 (plus $6.99 shipping and handling).
    Nov 26, 2009 | As Seen On TV Magic Bullet Food Processor
    My Magic Bullet has broken. I need to know how to get it fix.
    This happened to me, and I was told by the company that I had to purchase a brand new base, that the plastic turning device can not be repaired. If it is under warranty, you may not have to pay anything but shipping, and maybe not that either. If you do not have the number to the company, go on-line and and search for it. Call the company and report what the problem is.
    Oct 27, 2009 | As Seen On TV Magic Bullet Food Processor
    Food Processors Logo
    11,442 people viewed this question
    Top As Seen On TV Food Processors Experts
    gggg
    ray gallant
    ray gallant
    Are you an As Seen On TV Food Processor Expert? Answer questions, earn points and help others
