Will run briefly when primed through air cleaner. Jave replaced filter and cleaned carb.
Well if the unit has fuel than it should prime unless the primer bulb is damaged and unable to force air/gas through the line. This is definetly a fuel issue, I would remove both the line from the tank to the carb and carb to engine and clean them thoroughly.
When you press the bulb the carb should shoot gas from the unit when disconnected. If this isn't happening your clog is here. If it does eject gasoline than your clog is the clear line which sometimes collects sediment if the gas is poluted.
