I have a Kemore 80 series washer model 110.27812692. It does not fill with enough water. Any troubleshooting suggestions specific to this model? Thanks
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
If you go to: www.searspartsdirect.com and enter the 110--- model number (without the decimal point), you will get the drawings of all of the machine's parts. Select the control panel and you will find a water level switch listed (which may be your problem). If you go to the tub drawing, there is a hose listed that isn't shown how it is used. This may be attached from the level switch to a stub pipe at the tub bottom to sense water level (this is likely ok). Rising water level increases air pressure in the hose which in turn pushes against a diaphragm in the level switch and it in turn pushes against variable (by the front control) spring pressure and ultimately the switch that shuts off the incoming water. I hope this makes sense and helps you.
Isn't there some type sensor that tells the machine when enough water is present?
