Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch 100 series will not drain
Bosch Nexxt 100 series washer will not drain.
  • Anonymous Mar 16, 2014
    Drain
Barry Coates
Level 3:
  • Bosch Master 3,463 Answers
  • Posted on Mar 15, 2010
Barry Coates
Bosch Master
Level 3:
Answers
3463
Questions
Helped
1405812
Points
12766
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
  • Anonymous Aug 15, 2012
    I did this and it didn't really look like a filter, but I found nasty smelling water sitting in there so be prepared to wipe up about a quart of water. I found a hair pin in there that probably stopped the pump from spinning. Thanks!
    I found a hair pin in there which probably kept the pump from spinning. It didn't really look like a filter when I pulled it out. Make sure you put the white piece in properly (orientation is printed on the bottom). Be prepared to catch or mop up about a quart of nasty smelling water. Wipe the inside out well.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1189
Points
Bosch logixx SM69L02GB/02" dishwasher will nor draim properly or start another program
3 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Aug 05, 2008
SOURCE: will not spin or drain
no drain then no spin
check filter and check for foreign objects jamming the pump impellor - usually bits of bra wire
A
Anonymous
  • Posted on Sep 23, 2008
SOURCE: Bosch Nexxt 100 Series washer
Bosch Nexxt series 100 place clothes in machine start add detergent as always machine begins to add water for about 30 seconds then stops , sometimes stops and sounds like it is trying to drain sometimes just stops and won't unlock door even if you turn machine off. Sometimes if you switch from hot to cold washer will work just fine for a couple of days then back to just stopping.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 11, 2010
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
Bosch nexxt 100 washer keeps getting water in drum
Check the way the waste pipe is connected to sink drain,could be purge back from here or could be faulty/ leaky fill valve,
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Manual release on door lock of a bosch nexxt series 100 washer
Try pulling door up before out. My washer does this when the rubber around the door gets a piece of wet paper under it, or I have overloaded it and the rubber gets moved. Once open, run your fingers around the rubber seal to verify nothing under it and that it lays smooth.
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
How to raise the water level in a nexxt 100 series machine
Water level is set according to the pressure system within the machine and this is not adjustable, One thing to make sure of is that your waste pipe is not pushed to far into the drain pipe as this may cause sythoning, and thus you are in fact loosing water via drain pipe
5helpful
Thankyou.
1helpful
3answers
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
