Question about Toshiba Magnia 3300 Server
Toshiba Magnia 3300 server video problem
I have a Toshiba Magnia 3300 server with 2 X Intel Xeon processors(2.40Ghz) here is the problem.it starts but i see no image on the display.i have put a pci video card but nothing.the monitor shows me No signal.when i start the computer it blinks for 1 sec.but then it goes back to no signal.i mention that i have put the DDR1 memory (2 x 512) 400 mhz from my desktop.does this need another type of RAM?on the case it says pc2100,but i think it might work with pc3200 also.so what could be the problem?
    Master:
  • Toshiba Master
  • 126 Answers
DriverPack Solution driver update software Download Windows 7 XP 10 8 and...
try to reinstall all videos plugins like adobe flash
Posted on Jun 04, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Posted on Aug 19, 2008
Nerdy_geek
vic donald somera
  • 94 Answers
SOURCE: PROBLEM
here are some link for the error codes hope this helps.
ERROR CODE 7( NTKRNLMP.EXE) .http://support.microsoft.com/kb/812580
ERROR CODE 4 ( SETUPDD.SYS) .http://support.microsoft.com/kb/330181
Posted on Sep 18, 2008
Anonymous
  • 40 Answers
SOURCE: images and photos are blurred on internet
Try this:
1. Click the Tools menu, and then click Internet Options.
2. On the Advanced tab, click Reset.
3. In the Reset Internet Explorer Settings dialog box, click Reset.
4. When Internet Explorer 7 finishes restoring the default settings, click Close, and then click OK two times.
5. Close Internet Explorer 7. The changes take effect the next time that you open Internet Explorer 7.
Posted on Jan 29, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 04, 2009
BlacMamba
Myke Ogar
  • 215 Answers
SOURCE: My Toshiba p105-s6064 display screen is only
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Posted on Nov 10, 2009
Can i put dual core processors in my intel se7505vb2 motherboard?
http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm
Page 16 of the Technical Product Specification guide;
3.1.1 Processor Support
"The Intel Server Board SE7505VB2 supports one or two processors in the 604-pin FCPGA package."
-> Socket 604,
http://en.wikipedia.org/wiki/Socket_604
-> Intel XEON processors ONLY
"When two processors are installed, all Processors MUST be of identical revision, core voltage, and bus/core speed."
-> Means you really should use two IDENTICAL processors.
"When only one Processor is installed, it should be in the socket labeled CPU1, and the other socket must be empty."
-> Self-explanatory.
That's the processor socket furthest away from the black AGP graphics expansion slot, and closest to the outside edge of the motherboard.
(Page 104, and 105)
ONLY supports Intel Xeon processors with a 400MHz, or 533MHz FSB.
Dual-Core Xeon's start at 667MHz, and wouldn't work anyway; due to different Core architecture, and Instruction Sets.
667MHz, 800MHz, 1066MHz, and 1333MHz, for dual core Xeon's,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#Xeon_.28UP.2FDP.29.2C_Dual_Core_2
(Scroll down just a touch, to get the Wikipedia 'banner' out of the way, or click on it's X)
Scroll down the page, look at the charts. Starts with 800MHz FSB for Dual Core, then goes 667MHz, 800MHz, 1066MHz, and 1333MHz, Front Side Bus.
Use Dual Core processors?
No.
Two Single-Core processors.
Product Guide for the Intel Server Board SE7505VB2,
(Motherboard manual),
http://download.intel.com/support/motherboards/server/se7505vb2/prod_guide.pdf
The above is a direct link to the PDF file, motherboard manual.
If it doesn't work just by clicking on it, then copy it; and paste it in your browser address bar. Press the Enter key.
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, or press the Enter key; it may take up to 30 seconds before the first page comes up.
Didn't want you to wait a few seconds, and think nothing is happening)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2012 | Computers & Internet
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Nov 28, 2012 | HP Compaq ProLiant DL580 G4 (430811001)...
Recovery CD SG25
Sorry, the Client CD expired on December 30th, 2013.
Nov 28, 2012 | Toshiba Magnia SG25 Server
Just built new computer using an ASUS Z8PE-D12 motherboard. When I power it up, it keeps wanting to flash the bios. I just had to replace an identical motherboard doing the same thing. Removed all...
z8 is nice, I know for sure,
Z8PE-D12 the dual xenon server grade mobo, like my z600 works station has but HP made.
let me guess both boards never worked for you and you bought them on fleabay, and are DOA? that it, what is the story here.
Let me guess more, (no history at all)
you just put in a new CPU, xeon, ?
well if you did and
1: it is not support, it will do that.
2: or it needs flashed bios to support newer xeons.
3; no you can not run all xeon's made in this mobo ever.
first off put only one xeon the primary socket.
and only ram for just it.
then at ausu we site makes sure you are using the right xeons first.
the correct path is with working xeon, flash the bios.
then upgrade xeons last.
ok?
5500 series processor
1366 socket
Six-Core/Quad-Core Intel® Xeon® X5600 Series (130W)
Six-Core/Quad-Core/Dual Core Intel® Xeon® E5600/E5500 Series (80W)
Quad-Core Intel® Xeon® W5500 Series (130W)
Dual Core/Six-Core/Quad-Core Intel® Xeon® L5600/L5500 Series (60W/40W/38W)
Six-Core/Quad-Core Intel® Xeon® X5600/X5500 Series (95W)
here is the offical list.
newest BIOS is 1401
i bet yours is super old bios and not stated, or what xeons you have.
as you can see it is not trivial this topic.
https://www.asus.com/Commercial-Servers-Workstations/Z8PED12/HelpDesk_CPU/
it seems owning just 1
Dual-Core Intel Xeon E5502
as cheap as $5 60 on fleabay will allow flashing this mobo firmware, worst case.
Feb 06, 2018 | ASUS Z8PE-D12(ASMB4-IKVM) Dual LGA 1366...
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Jun 29, 2011 | Compaq Evo Workstation W6000 PC Desktop
Cannot access admin functions toshiba magnia sg20
If it was unplugged for any period of time, it is probably reset to default settings. Password is default, etc and you are trying to access with the wrong credentials.
Try resetting it manually and starting as if you just purchased it, if you continue to have problems. There should be a reset button or procedures on how to reset in the documentation.
Apr 23, 2010 | Toshiba Magnia SG20 Server
Upgrade Processor for 3300 Magnia Server
It supports Intel Xeon processors.socket 940 i think.xeon cpu`s @ 1.8 Ghz or 2.40 Ghz with fsb 400 Mhz,and L2 cache 512 kb
Mar 11, 2009 | Toshiba Magnia 3300 Server
Mainboard for server Magnia 3310
Try Googling (Toshiba)(3310)(manual) without parens.
Nov 05, 2017 | Toshiba Magnia 3310 (syu3910w-000z1)...
Magnia sg20
Hi Steve You have to download Hiren's BootCD which will gives you all the tools you needed... Thankyou
Aug 22, 2007 | Toshiba Magnia SG20 Server
Toshiba Magnia 3300 Server Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
