Washing Machines Logo
Posted on Mar 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Initial Power surge
Need to know the startup power surge of zanussi 1300 washer expressed in watts Machine to be installed in canal narrow boat need to know if my inverter will be able to handle the surge
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
  • Posted on Mar 09, 2008
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1147065
Points
9064
Look on the back of the unit, for the average numbers for volts/amps..multiply that by 1.66(for peak power) and add a factor of 25% for power factor correction from your inverter. You may want to place a resistor/diode array in line with that, so that any reverse surge from the power cycling of the washer, won't back up your inverter feed.
1helpful
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
2answers
Replace integrated Radeon 4200
You can't replace integrated graphics, the chip is on the motherboard.
See what you have for PCI-E slots, a forty dollar graphics card is three times better then your 4200.
Is not Reading My Geforce GTX 260 Card
What do you mean connect wire to graphics card?
A) Computer is to be OFF when connecting a monitor cable.
B) Computer is to be OFF, and unplugged from power; when plugging the power cable from Power Supply, into it.
You are also supposed to be Following Anti-Static Precautions.
What Power Supply are you using?
Manufacturer name, and model number. Post back in a Comment.
Motherboard requires about 150 Watts by itself.
That isn't including what the Processor (CPU) needs, Ram Memory needs, optical drive/s need, computer case fans need; AND what the Nvidia GeForce GTX 260 graphics card needs.
It needs 225 Watts by itself.
(Manufacturers usually state around 500 Watts MINIMUM.
This is in reality based on a COMPLETE computer system, and NOT just the graphics card itself)
What do I base that the GTX 260 needs 225 Watts?
(I see that as the -> Maximum, though )
A PCI Express x16 expansion slot on a motherboard, is only capable of 75 Watts of power.
That is why the additional power cables were brought out.
The 6-pin PCI Express power cable that plugs into the GTX 260, is capable of an additional 75 Watts of power.
The Nvidia GeForce GTX 260 requires using TWO 6-pin PCI Express power cables
That means 150 Watts of additional power.
75 Watts + 150 Watts = 225 Watts
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-260/specifications
"Supplementary Power Connectors -> 6-pin x2"
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
If you are using just one 6-pin PCI Express power cable, '
this = NO.
NOT enough power for the graphics card.
What will happen?
A) The PCI Express x16 slot connector oins, will burn
B) The gold plated contact pins on the bottom of the graphics card, will burn.
C) The connector on the graphics card, that the 6-pin PCI Express power cable plugs into, will burn.
D) The connector on the 6-pin PCI Express power cable will burn.
The graphics card will burn up.
Too little power.
IF, your Power Supply has enough power, and IF there are two 4-pin Peripheral power cables that aren't being used; you can use a 6-pin PCI Express power adapter cable.
Example of 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Example of 6-pin PCI Express power adapter cable, was shown in the Playtool link,
http://www.directron.com/pci03.html
(Connectors are white, and hard to see against white backdrop. You can enlarge all 3 views)
For additional questions please post in a Comment
Regards,
joecoolvette
4helpful
2answers
Which video card do i use in a vcg rb50
Dear,
you have pci express slot that supports high graphic card. You can buy a high graphic vga card but it relates with your power supply too. Check your power supply wattage and then buy the vga card accordingly because high graphic vga card require more power from supply.
There are alot of pci slot supported card in the market.
best of luck!
I would like to run my frigerator if possible , off an inverter if our power goes out from a hurricane. I need to know the surge draw in watts for the start up and the running draw in watts after...
During the 2 peak power usage times of the refrig,on start up and during the defrost the max wattage would be 1320 assuming the compressor might potentially be tight using more power to start than if it were/is normal for a max of as said 1300 with the normal statrt up be around 800. and when running after starting it would be a max. of 500
I had a power surge, new washing machine has no power
if nothing obvious fried then call warranty service, omit part about power surge!
2answers
ZANUSSI 1237 Washing Machine
have you tried to plug your machine in a different socket try it if you can by using an extension instead of moving the machine.
Top Washing Machines Experts
john h
