Our Vizio speakers make noise the entire time the t.v. is on. What can we do to fix this problem?
VIZIO VX37L backgroud buzzing noise constatly (audio) increasing as volumne increasing. My knowlege is limited but tried looking at audo conttol setting,(nothing in which I could relate) also I found under advance picture adjustment DNS (noise reduction). it didn't seem to realate to aduio. If audio is fine and new speakers would cure all, I'd be a player.
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
I am a victim to this every so often. My solution, although I can't explain, is simple. I activate the menu setting on my Comcast HD box & select "restore defaults". Buzzing stops every time.
I seem to have fixed the buzzing from my Vizio, by just lowering volume on my optimum cable remote and also lowering the volume(to zero) on my insignia tv's remote. This has been working for 2 days. My problem was that the speaker was working for about a minute and then BUUUUUUZZZZZZZZZ!
The lettering on top and bottom does not show
Mr Soundman 7, you were right on the money. My sound is now perfect! I didn't how to change it, but I called my cable company. The first person didn't know how and set an appt for me. Last night a Brighthouse technician called and he was able to walk me through the solution. He said you nailed it & you saved me from waiting on an appt. Many Thanks
the bottom speaker sounds like it's blown but I removed it and tested it and it was fine.It comes and goes.Is this a known problem for vizio
I have a L37 vizio tv and right side speaker sounds like is blown
does any ones knows what is going on with my tv????
thanks for your inputs
same here
awesome, turning up the hd box got rid of the *** buzzing noise! nice work!
lcd television speaker is making a buzzing noise. i adjusted balance of speaker to other side and it stopped. is it a blown speaker?
