Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iam trying to make my behringerXENYX 1204fx mixer, / connect
IM trying to make my behringer XENYX 1204fx mixer, / peavey pa-400 system, / windows xp desk top, all work together as one,but my brain is not working with me. So , my brain and i need someones better brain to help me solve this problem. THANKS,FOR YOUR HELP~~ppppppp.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
912
Points
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Anonymous
Level 1:
New Friend:
  • Posted on Apr 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
912
Points
How do i connect my cd players and laptop to my beringer 1204 fx mixer.....and then to a power amp for speakers. not sure where to begin or what leads goes where....
Anonymous
Level 2:
Scholar:
  • Expert 75 Answers
  • Posted on Mar 13, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
75
Questions
5
Helped
32514
Points
154
From the mixer mains output u should have  two TRS jack output terminals or  XLR type (round socket with 3 little holes)  (sometimes they call it balanced output/input terminals).
1. buy 4 cables of  TRS (1/4" size / 6.35mm)connectors
2. two nos of 6.35mm to 3.5mm TRS adapter that has two 6.35mm socket on each adapter. one adapter is for input to computer from the mixer and the other adapter for output from computer to power amp.
3. connect one TRS adapter to audio input port on computer and connect with mixer mains output
4. connect one TRS adapter to audio output port of computer and connect to with power amp input.
5. each connection will have 2 balanced input to computer and two balanced output from computer.
       So, the main idea is -  from mixer to computer and from computer to power amp. If u have six audio ports u can connect left and right channel on two separate ports for both input and output. This u have to configure from ur PC.
      Left /right input on one port and left/right ouput from one port also works well.
3.5mm TRS is the one used on most headphones
2.5mm TRS is a miniaturised version usually used for mobile phone headsets.
I have a Behringer Xenyx 1204FX and the DSP Display doesn't illuminate (but works by pressing down and turning the knob). Any idea why it's not on? Also the AUX 1 Send doesn't seem to be working
It sounds like you're experiencing a couple of issues with your Behringer Xenyx 1204FX mixer. Let's address each of these problems separately:
  1. DSP Display Not Illuminating: The fact that the DSP display works when you press down and turn the knob suggests that the issue might be related to the display itself or its connection. Here are a few steps you can take to troubleshoot the problem:
    • Check Power Source: Ensure that the mixer is receiving proper power and is turned on. Sometimes display issues can be caused by power-related problems.
    • Connection: Make sure the ribbon cable or connector that connects the display to the circuit board is properly seated. A loose connection could be causing the display to not illuminate.
    • Faulty Display: If none of the above steps work, there might be a problem with the display itself. You may need to contact Behringer support or a professional technician to get the display repaired or replaced.
  2. AUX 1 Send Not Working: If the AUX 1 send is not working as expected, there could be several reasons for this:
    • Routing Settings: Make sure that the AUX 1 send is properly routed to the desired destination. Check the routing options on the mixer to ensure that the signal is being sent to the correct output or destination.
    • Level Controls: Verify that the level controls for AUX 1 are set correctly. Make sure that the AUX 1 knob for the specific channel you're working with is turned up.
    • Effects/Processing: If you're trying to send a signal with effects applied, check if the effects are set up correctly. Sometimes, an incorrect effect or routing setting can affect the AUX send.
    • Cable and Connections: Ensure that the cables connecting the AUX 1 send to external devices (such as monitors or effects units) are functioning properly and securely connected.
    • AUX Master Level: Confirm that the AUX 1 master level (usually located on the main output section of the mixer) is turned up to an appropriate level.
If you've gone through these troubleshooting steps and the issues still persist, it might be a good idea to consult the user manual for your Behringer Xenyx 1204FX mixer for further guidance. If the problems continue, you may need to reach out to Behringer support or consider seeking assistance from a professional audio technician or repair service.
No effects output xenxy 1204fx
Likely needs the DSP board replaced. It is the small board held on by 2 screws(if I remember correctly) and is easily replaced. I think retail cost is about $30 and can be ordered directly from Behringer.
I have a Behringer 1204FX mixer. It has an intermittent fault whereby the power supply pulses on off on off etc etc. This can continue for two minutes or ten minutes quite randomly.
That is known as :squegging". It can be caused by any of several failures. One failure involves overload that trips the overload sensor. Another is a problem in the feedback loop of the regulator. I would first replace C13 on the power supply and maybe C10. When working on these supplies use an isolation transformer for personal safety. Note that it appears that C13 MAY have too high a voltage rating and if an electrolytic the dielectric can deform and electrical value reduce. There are many other components that could cause the problem.
Best way to connect 2 1204FX mixers together
Try running the tape out of the slave to the tape in of the master unit. This us haywire, but should work. Use a stereo RCA cable.
1helpful
I purchased a PV12M monitor and was wanting help connecting it to my Behringer xenyx 2442fx mixer
You will have to have an amplifeir between them since the PV12M is an unpowered speaker. The Xenyx 2442FX is likewise an unpowered mixer meaning it cannot directely drive a speaker. You will wire with a balanced line (TRS cable) between the 2442 and the amp and then from the amp to the speaker using a speaker type cable.
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
5helpful
2answers
Beringer Xenyx 1204fx emits a clicking sound... Sounds like a Geiger Counter for radiation in my headphones. I have used the same sound mixer in the same configurations for 3 weeks. Now I've had it...
This is likely a problem with the FX in the unit or the power to it. Does the FX display act correctly? Check that the headphone source "Main Mix" is the ONLY button down for the headphones. If not, make it so. If the clicking is still there, try the headphones in the aux send jacks... see if EITHER left or right can hear the clicking. Back in the phone jack, scan across the SOLO channel buttons down one at a time. Is there clicking? If not, the problem involves the mixing buss or further down the line. Make sure the SOLO buttons at the FX Aux sends are up.
What effect does the MODE button have in SOLO and in PFL? Is the SOLO LED off? Is the number in the FX window SOLIDLY on and not flashing?
1helpful
Do I need to connect the Xenyx 1202 to an amp?
If you are the only person listening, you can use headphones with the headphone jack. Otherwise you will have to use some sort of amplification and speakers,e.g. P.A., stereo etc. I'm using a Xenyx 1222 FX and am quite happy with it.
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
