2001 Ford Taurus Logo
Anonymous Posted on Mar 11, 2010
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the part in the state of washington?
DROPNDEAL
Level 3:
Top Expert:
  • Ford Master 2,931 Answers
  • Posted on Mar 11, 2010
DROPNDEAL
Ford Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932220
Points
21770
Www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Testimonial: "thanks so much for all the help. I'm pretty mechanical and can probably do it myself. Thanks again, this is a great site. tom hart"
Wayne Fellows
Level 2:
  • Ford Expert 262 Answers
Wayne Fellows
Ford Expert
Level 2:
Answers
262
Questions
Helped
246037
Points
802
Water Pump Removal
  1. Drain engine cooling system. Refer to Section 03-03 .
  1. Remove engine appearance cover as described in this section.
  1. Remove battery (10653) and battery tray (10732) . Refer to Section 14-01 .
  1. Remove drive belt (8620) from water pump (8501) and water pump pulley (8509) .
  1. Disconnect water bypass tube (8548) , heater core return hose and oil cooler return hose from water pump .
  1. Remove two bolts retaining water hose connection (8592) to water pump housing. Pull water hose connection away from water pump and remove water thermostat (8575) from water pump housing.
  1. Remove bolts and collar retaining water pump housing to LH cylinder head (6049).
  1. Disconnect water outlet hose and water inlet hose from water pump and remove water pump from engine.
  1. Remove retaining bolt and belt idler pulley (8678) from water pump housing.
  1. Inspect water pump for wear or damage. Replace components as required.
    Installation
    1. Clean water pump-to-water pump housing gasket sealing surfaces.
    1. If removed, install water pump belt idler pulley and retaining bolt to water pump housing. Tighten retaining bolt to 10-16 Nm (89-141 lb-in).
    1. Lubricate water pump inlet hose, outlet hoses and O-ring with Ford Extended Life Engine Coolant F6AZ-19544-AA or DEX-COOL® equivalent that meets Ford specification WSS-M97B44-D. Install water pump inlet and outlet hoses onto water pump housing. Install water pump outlet hose spring clamp securely.
    1. Place O-ring between water pump housing and LH cylinder head.
    1. Install bolts retaining water pump housing to LH cylinder head . Tighten two retaining bolts at water inlet to 8-12 Nm (71-106 lb-in). Tighten two remaining retaining bolts to 18-28 Nm (14-20 lb-ft).
    1. Install water thermostat, oil cooler return tube gasket (6N789) and water hose connection to water pump housing with two retaining bolts. Tighten to 8-12 Nm (71-106 lb-in).
    1. Install throttle body return and supply hoses, heater core return hose and oil cooler return hose to water pump .
    1. Install water pump drive belt. Carefully release drive belt tensioner (6B209) . Refer to Section 03-05 .
    1. Fill engine cooling system. Refer to Section 03-03 .
    1. Install engine appearance cover as described.
    1. Install battery trayand battery . Refer to Section 14-01 .
    1. Run engine and check for coolant leaks.
    Item Part Number Description 1 8A577 Water Outlet Hose 2 8548 Throttle Body to Water Pump Return Hose 3 8548 Water Pump to Throttle Body Supply Hose 4 95827-08110 Bolt 5 8501 Water Pump (2 Req'd) 6 8575 Water Thermostat 7 6N789 Oil Cooler Return Tube Gasket 8 8592 Water Hose Connection 9 95827-06020 Bolt 10 8287 Heater Core to Water Pump Return Hose 11 90116-08604 Stud 12 6B851 Oil Cooler to Water Pump Return Hose 13 8620 Drive Belt (2 Req'd) 14 95817-06045 Bolt 15 8678 Belt Idler Pulley 16 6A359 Water Pump Drive Pulley 17 90387-082T8 Collar 18 8K540 O-Ring 19 8548 Water Inlet Hose 20 95827-06025 Bolt A — Tighten to 18-28 Nm (14-20 Lb-Ft) B — Tighten to 10-16 Nm (89-141 Lb-In) C — Tighten to 8-12 Nm (71-106 Lb-In) I have a 1999 Ford SHO that needs a new waterpump. - 70a97a2.gif
I have an 05 ford taurus waterpump bearings in pulley are shot can i just replace the pulley? Instead of the whole waterpump?
no if you found a bearing kit [ theirs probably one out there somewhere ]] but cheaper and easier to just replace the pump and even if kit was available need special tools to press and change them
1helpful
I am looking for 2007 Ford Taurus SHO or SES
Ford didn't make the Taurus sho in 2007. The sho were made between 1989-1999 and then 2010-present. In 2007 the Taurus was only offered in SE and SEL trim.
I need a tool used to repair the lifter in a ford explorer
there is not special tool. you have to take off the lower intake manifold and both head to replace the lifters. I rebuld motors all day in my garage . it is a big job
REMOVE WATERPUMP PULLEY ?
you need a special tool to remove the pulley. go to the parts store the rent this tool. when you bring it back they give your money back for it
Broken serpentine belt on 1999 Taurus SHO
i needed a certain diagram also ang just googled serpentine belt diagrams and it took me to a site and iit was free but i didnt save the name try google
I need to replace injector cups first i need to know where the injectors are 1999 F350 7.3 turbo
SORRY BUT IF YOU NEED TO ASK THAT QUESTION YOU ARE IN WAY OVER YOUR HEAD!
ALSO SPECIAL TOOLS ARE REQUIRED.
BUT FYI, UNDER THE VALVE COVERS DIRECTLY OVER EACH CYLINDER
8helpful
2answers
1999 Ford Taurus, replaced leaking master cylinder, installed new brake pads, bled brake lines, pedal still soft. What else can I check?
There is a special tool required to bleed the brakes, it plugs into the ABS hydraulic control under the hood and holds the ABS valves open to remove the trapped air during bleeding, u will need to have the dealer bleed the brakes, they are most likely the only ones that will have this special too, but u can try an outside shop, I am sure Snap on tools makes this tool in the aftermarket tool catagory..
14helpful
Special tool to remove water pump on 1999 cadillac deville
remove air filter housing,remove secondary air check valve bracket,if equipped,remove lower radiator hose from the thermostat housing,remove waterpump bypass hose, remove waterpump cover,use special tool to remove waterpump,install a new o-ring inwaterpump housing
Altenator
Unplug the alternator remove ground to motor.
Remove serpentine belt.
remove 2 bolts which hold alternator.
replace reverse of removal.
4 out of 10 difficulty.
Only special tool you will need is a wrench long enough to pull back the tensioner.
See the radiator support for location of tensioner and serpentine routing.
While its off, i would suggest replacing the belt too.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
