My Electrolux EWF 1087 washer always come up with an error code of E60, Why? can any one help
My Electrolux washer always come up with an error code of E60, Why? can any one help
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customer error codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
I had the same problem.Pull out the filter thing at the bottom and clean out under running water.Check everything is clean.Put it back in making sure there is nothing coming inbetween the filter and machine.Mine worked after this.There is no Err 60 in the manual.If it works(Err 60 is gone) run a maintenence wash on it-by selecting the hottest temp setting and using liquid detergent if possible.then it should be clean and good to go.Good Luck :)
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
User manual tells you what faults are
could be blocked inlet valve not filling in correct time or pump blocked
not draining in correct time
I need help my washing machine keeps beeping in flashing E90 as an error. I have cleaned out the filter at the bottom of the machine, what else do i need to do
Hello - Are you certain the error code is E4H? This manufacturer does not have any E4H error code for any washer or other units. They do have E4A and E5A codes however.
I keep getting the E60 msg and the machine just beeps and does not work. There is nothing in the instructions manuel for this code, what should I do
Front loader
