You have to know if the FOCUS is the issue or SHUTTER SPEED. In most cases with most CoolPix Cameras if the Image is not in focus (When you push shutter down HALFWAY) the Focus Rectangle will not be GREEN... If it RED it cannot focus. If every time you take a photo the focus area is red then it is not focusing. Small Coolpix cameras have difficulty focusing in low light.
Low light can make a hand held image look blurry because of hand shake. If the light is so low it wants to take a long exposure. This works with a tripod, but not with a hand held photo. With most of these small cameras you can take 1 second night photos with a tripod. They would look horrible handheld.
Typically on the Coolpix cameras you can set the FOCUS mode. It is usually shown with a FLOWER for MACRO... You get AF / FLOWER / MOUNTAIN / MANUAL (may not have this)
Plase make sure your FOCUS MODE is in AF AF is the ONLY Mode where the camera will focus CLOSE and FAR... Light is not your problem..... It seems it is your FOCUS MODE.
Unfortunately, most auto-focus systems require some light to focus with. My cameras have a "focus assist" light that throws a grid of lines out so it can focus. My wife typically covers this light with her hands, and so can't get it to focus in the dark. Check for that.
repairpal.com > Questions > Ford > Focus > 2002 Ford Focus
Feb 20, 2009 - I have had these tow lights on due to emissions leaks. No one has been able to tell me ... Engine and Fuel light on due to emissions leak on 2002 Ford Focus. I have had these tow ... engine light is comming... 2004 Ford Focus ...
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Depending on your lens, you may have an AF/MF switch. Make sure it's set to AF for Auto Focus. Try increasing your light levels. Does focus work in a good light setting?
You should have a button that looks like a matrix. Press this button to set your focus point. Use the joy-stick like wheel to select the focus point. Press it to select Auto Focus points.
I have the same problem with my 03 Focus hatchback! Someone stoppedme yesterday to tell me that they looked like they were always on when i was driving but when i was in "Park" they worked... This particular driver was also driving a focus hatchback and asked me if my Cruise Control was working.. It actually was not and he told me the same thing happened with his focus. He said it was a wire attached to the back brake lights that had broken. I have not yet gotten it fixed. has anyone else had this problem?
Just a wild guess, but in predictive AI focus mode you need a subject in motion for focus to lock and focus adjustment is continous until the exposure is made, in one-shot AF or manual focus mode focus will lock on still subjects. Super nice camera btw.
1) Being connected to your studio lights is interfearing with the camera's electronics, disturbing its ability to focus. Does it focus if you're not actually connected to the studio strobes, but are trying to focus using just the modelling lights?
2) There may simply not be enough light for the camera to focus. Canon sells a red LED AF illuminator that sits in the hotshoe (can't remember the part number). That may help. Also, if your modelling lights are set to "tracking" or "proportional", try setting them to fixed full power. You've probably got the strobes set several stops lower than full power, so "tracking" modelling lights rob you of several stops of focusin light. Or try a faster lens.
All auto-focus systems need a fair amount of light or contrast to work efficiently. If possible, raise the ambient light if indoors. Search for an area within the desired focusing point with contrast to focus on.
