SOURCE: puk code for a t mobile g1
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
SOURCE: Iphone PUK code
The PUK varies from sim to sim, and is used to unlock a sim card if you forget the sim pin that you would have set. You will have to contact your provider to obtain it, unless you have the certificate that came with the sim card in which case you can probably find it there, but no one keeps those. So call tmobile or whomever you use.
SOURCE: HOW CAN I UNLOCK GLOBE SIM CARD PUK CODE?
Hey I can solve this!!!!!!!!! ok step 1 : do you have friend that has a sim card? well if you do ask to barrow it then insert it step2: go to itunes and your iphone should come up step 3: ask him or her to insert there Billing Zip Code (i forgot to mention this, when itunes reconizes the iphone it will ask you to register it or whatever click continue) and ask your friend to put his or her personal **** such as email address an LAST 4 DIGITS OF SOCIAL SECURITY NUMBER!!! step 4: when thats done it have to install then it will let you into itunes then sync your music,videos yadda yadda yadda then pop out the sim card WARNING do not put your real sim card or it will do this **** all over again ALSO i do not know yet how to make calls or just look up fring its a app(FOR FREE on itunes) that allows you to make calls WITHOUT SIM CARD look it up
Overall (depending on the speed of your computer ) it should take 5-10 minutes and aslo you have your friends number programed onto your iphone but its better than trying to guess the PUK/SIM PIN
SOURCE: verizon apple iphone 4s Sim Puk Unlock Code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
