Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
ok i changed the brushes,simple put the machine on it's side,take off the motor, (2 bolts). there are two little metal notches holding in the brush.bend them back to allow the brush to come out.
the brush is a little fiddly to put in as there is a spring involved,but only needs a little patience. ps this machine has done an average of nine washes per week for five years and nine months
