I have a Traeger Executive 100 with a digital thermostat. Just recently when I turn the grill on just to the smoke level the thermostat reads 510 degrees. I had another digital thermostat, which I installed and got the same results. I have an accurate dome thermometer and it only gets up to a little over 200 degrees. I put the original smoke, medium, high controller and I got the temperature up to 400 degrees on high.
Do you get an error messsage that looks like LEr? If a Traeger can't reach 125 for ten consecutive minutes, it will automatically shut down. Try starting at a higher temperature than "Smoke" if it's cold outside. Traeger also makes "blankets" to help your smoker maintain temp in cold climates, but they're quite an investment.
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Traeger grills just will NOT smoke at temps much above 200 degrees. I have to stand by my grill continually in the summer to keep opening and closing the lid to let the heat out. That also lets the smoke out. I also have turned the grill off and on to try to maintain the temperature at 180 degrees where it smokes best and cooks low and slow. It's less of a problem in the winter months. Then I find myself setting the temperature higher turning it from low to medium and back to maintain the temperature I want.
Make sure you are leaving it open long enough when you first turn it on. Everything in the smoke chamber needs to burn up before you begin. There also may be grease buildup in the bottom of your smoker that is catching on fire. If neither of these two possibilities work, contact Traeger support https://www.traegergrills.com/support
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
