Model gd5shaxLT02 stopped making ice. Looks like the fill line is frozen. Don't know if I need a new valve or not (may be leaking) but how do you get to the valve?
The water inlet valve on the back of unit where the water supply connects opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
