SOURCE: Need to replace the glycol oil (coolant) in our rear projection tv
You can get The Picture Tube Coolant at the link here Matt electronis. they offer quick shipping, And if you need instructions on how to do the proceedure , please let me know
http://www.matelectronics.com/cgi-bin/ss000001.pl?SS=coolant&PR=-1&TB=A&SHOP=&ACTION.x=16&ACTION.y=9
SOURCE: How can I flush my whole coolant system
Preferable to flush as much out as possible to get rid of the old stuff and can be done at home by undoing the heater hose at the fire wall and using the garden hose to force water through until it comes out clean Dont turn hose on full blast as it will spray out over everything build up to it so it doesnt make a mess.Make sure the heater is in the on position so that water comes out the pipe you took the hose off.Either way though it will still be ok to just undo the bottom radiator hose as the majority of it will come out.
SOURCE: intermittant low coolant light. Have
The coolant sensor located in the radiator is either gunked up or faulty if the fluid level stays ok.. The sensor is located on the engine side of the radiator about 3 inches from the top on the right side looking from behind the steering wheel
SOURCE: i did a coolant flush and bleed the system and it overheats
On the top of the radiatorr there is a plastic screw that has a head similar to a Phillips screw, this needs to be removed to bleed the air out of the system and prevent air pockets. Take both the screw and the radiator cap off when filling the system and add your coolant to both holes. Let the car idle while filling with the heater on so the whole system is circulating and watch for the bubbles to come out. Fill the radiator right to the top, replace the two caps and you should be OK.
SOURCE: proper method on coolant system flush
Best way is to buy a flush kit. It is an adaptor that you put in your heater hose and can hook up a garden hose to. You cut the hose and put this device permanently in the line. Remove the thermostat, don't put the new gasket in there yet just put the outlet pipe back on and bolt it down. Run the car when cold with your hose running for about 10 minutes with the radiator drain valve open on the bottom of your radiator and the cap loose, water should come out of the drain valve and the radiator cap. This will flush your engine adequately, why waste money on distilled water, save that for topping off your battery. Turn off your engine continue to allow water from your hose to flow as long as you are seeing any thing other than clear water flow until it flows clear. Turn off the hose, put the cap on the flush port you installed. the port stays under your hood and allows you to flush your engine as needed. Let the water drain through the drain valve. Put in a new thermostat, with a gasket this time. Refill with water and antifreeze as directed in your manual. You should be good to go.
