I am having trouble cutting a 45 degree angle on my Dewalt 744 table saw. I have two original throat plates, one narrow and one wide. I am trying to use the wide throat so I can cut a 45 degree angle and it rubs hard on the side of the throat plate. I did not turn the saw on yet. I would think the wide plate would be standard for cutting a common 45 angle. Any suggestions? Should I try and make a new throat plate?
I don't know why it's rubbing, did you try the small one to see if it is different in some way? How about the stop screw, is it 45 degrees or more? Check it with your speed square. And yes, make a custom plate out of plywood. Which way does the blade tilt? Left is best, locking your work against the fence is the worst idea I have ever seen, (delta) It sounds like the big plate is for a dado blade.
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
