Water let into the tub for rinsing drains out immediately
The drain hose needs to be higher than the tub or it will drain out. If it is higher than the tub, unless you have a leak it would overflow the tub Good Luck
Remove the back wall of washing machine and check valve at the drainage pipe it must not be clean or having mud over it clean it i am sure it will be ok
This is possible if the drain hose is not kept at a minimum height of 24 inches from the bottom of the machine.
