Several reasons the ice maker could stop ruinning / Ice jammed up inside the ice maker that needs to be removed, the ice bar or sensor sences the bucket is full and not making ice, and the most common is the Water filter has not been replaced and has gone bad. I have run your model number and found that it does have a water filter in the fridge compartment, its a canister filter. If you havnt changed the filter, I would suggest taking it out or heading to your nearest hardware store to get a replacement.
DrakeTech
Check the water line that goes from the house plumbing all the way to the inlet on the 'fridge. Are there any kinks? Dirt obstructing the line? You MUST BE VERY CAREFUL when pulling the 'fridge out to check. If you have a copper line, it takes NOTHING for one to kink. And as soon as it kinks...it's done.
