You can disable the pin code in your phone on tools folder, or settings , select security and look for the pin code options there, enable or disable, select disable and enter your 4 digits pin code which was provided by your network, if you have changed the default pin code(which was provided by your network), enter your current pin code (code which you use to replace the default pin code) and pin security will be disabled.
good luck and take care.
SOURCE: sim card (punk)code
I advised you to call the telekom operator of which SIM card you were using.. The operator will assist you to make your blocked sim to be recovered.
The operator will need the information at the back of your SIM card which is the numbers written at the back..
Hope it helps..
Enjoy
Pls. rate & hope to hear more from you..
tnx
-micro
SOURCE: sim card blocked
Because its PUK (pin unblocking key) that is provided from u r Cellular service provide they set the security for sim if u enter wrong puk more that 10 time u r sim will be block That not able to use again u need to contact u r Cellular service provide they will gime u new sim with same no.
If u have entered a wrong PUK no. less than 10 times, then u can contact customer care and get the PUK unblocking code (its free). Remember each sim card has a different unblocking no.
If you have entered wrong PUK no. 10 times or more, then this SIM card is blocked and will have to be replaced by a new one. You need to visit any airtel franchisee, purchase a new sim, and they will delete your old sim card details and add the details of new sim card into their system. A new sim probably costs around 245/- (i think, though don't remember when i purchased it last). You need to carry old sim card + ID proof + any airtel bill (if postpaid, may get required).
If your connection had been a Postpaid with regular payment history, I would have applied a different approach
Thanks,
Appereciate to rate as "FixYa"
SOURCE: lost sim pin
If you have lost the PIN code, the only choice is entering the PIN three times so to trigger the PUK code request.
Once you get the PUK code request, the PUK code can be obtained contacting the company that released the SIM.
The only other alternative to find back a lost PIN is going to a Phone shop. They will do same things as above.
Regards.
SOURCE: bsnl sim card rejected
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
