In the process of changing computers,i need to not only change the cables but can no longer find my cd for th scanner is there any hoe for me?? i have a dell desktop with Vista 64 bit OS. i am not sure what other info you might require
Re: In the process of changing computers,i need to not...
From this it appears that the 2400p does not run on Vista. Also it does not appear here in the list of scanners compatible with Vista. See this about an upgrade/exchange or go here and download the Universal Driver.
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/http://67.20.82.163/
<p>In general, all manufacturers provide information on the registration
of their products. By registering your barcode scanner, allows easy access to
guarantees, technical support and maintenance and notification of product
announcements, updates and offers. The record provides a record in case you
need a replacement due to theft or damage. In return, the company your personal
information to send you announcements and discounts on your scanner and other
products they sell. <br />
<p><br />
<p>1. Go to the manufacturer's website. Determine if the
barcode scanner to register online or to install the necessary drivers and the
registration process. If not, connect the barcode scanner to your computer via
the USB cable. <br />
<p><br />
<p>2. Turn the scanner installation CD into your CD-ROM. Please
wait while your computer loads the driver installation wizard. Follow the
wizard and install the software. A window will open asking if you want the
scanner to register. Select "Yes" and wait while your web browser
opens to the registration website. <br />
<p><br />
<p>3. Enter the information requested on the on-line
application. The typical form requires your name, e-mail, model and serial
number of the scanner. Also, some require a product key or registration. <br />
<p><br />
<p>4. Click the Send button to send your information and
complete the registration process. <br />
You get printer install software from the manufacturer. Usually for free. Be sure to download the correct software for your operating system, there have been lots of changes, and each one is different, no biggie, just pick the correct one.
You mention no brand name, or we could help more. Many printers SHOULD NOT be installed via "plug and play". Typically the printers lack functionality.
Just follow the directions exactly.
New things in printers are home network printers. They work similar to a printer hooked up to your machine, (meaning each computer can scan, rather than have to push buttons on the printer or go to the computer hosting that scanner, for example).
Radio Shack no longer sells the frequency software for this scanner. the drivers for your computer are on the cds you have so hold on to them they also are no longer available. radioreference.com may have the software for programming
first of all check all components of ur scanner is correct , power cable and usb cable connected to ur usb port of laptop back panel. then install the driver for ur scanner and follow the guidence of manual and after installing the software it will ask u to restart computer . when u done the process of restaring ur laptop it will say new hardware found and click on next and choose auto then click ok . it will install driver for ur scanner , it will surely works
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Locate the HP Photo & Imaging software CD-ROM that is appropriate for the language and operating system and insert the CD-ROM disk into the computer.
For a Microsoft(R) Windows computer: Follow the instructions on the screen. Or, if the installation program does not start automatically:
Click Start , then click Run . The Run window will open.
In the Open box type: X:\SETUP.EXE (where x is the letter of the CD-ROM drive).
If the instruction prompts to shut down the computer, do so.
Connect the USB cable between the USB port on the scanner and the USB port on the computer.
Connect the power cable between the scanner and a surge protector or a grounded wall outlet. This turns on the scanner.
If necessary, turn the computer on again.
this product is no longer being supported by HP so here is a link to updated drivers if needed. http://www.softwarepatch.com/utilities/hp-scanjet.html
hope this helps. please rate me and thanks for choosing enterprise computing solutions
Please change the your usb cable. and reinstalled same drivers..
it will work and go to the My Computer --> right click--> Manage-->go to the Device Manager click that one it will show the all the computer hardware drivers list..scan for hardware changes..
you'll see the your usd scanner it is detecting. or not..
If the technician who changed your hard drive was able to transfer ("clone") the system from your old drive, all you need to do is plug your printer/scanner in and it should work. If he was not able to do this and you have a new Windows installation, you need to use the CD that came with the printer to re-install it. Just connect up the printer to the computer BUT DO NOT TURN THE PRINTER ON UNTIL TOLD TO. Start the computer and when Windows has loaded, put the CD in the CD drive. The CD should start the installation process - just follow the instructions. If you do not have a CD, download the necessary installation software from the Epson website.If you don't know how to do this, report back and I will provide more help.
