I have a kitchenaid 5ksm150(UK),recently purchased an ice-cream maker in US. On beater shaft there is a collar between spring and cam stud. Can this stud be removed to take collar off allowing fitting for ice-cream maker, and if so how does it detatch
Dear kelpies52 I am having the same problem with a machine purchased from a KA dealer in Spain. Where did find the converter kit? Thank you!
Hello KELPIES52. I see you have two postings, with some minor differences. You say purchased an “ice-cream maker attachment” in the US and my first clarification question to you is, did you purchase the KA Ice Cream Maker, Model KICA0W, or some other brand that said it was compatible with KA mixers?
If you did buy a KA ice cream maker, then it should fit all KA models, including yours. If you purchased another brand of ice cream maker, then it may never be truly compatible, and there’s the rub.
First regardless of what brand of ice cream maker you purchased, you should have both your KA mixer’s Parts List manual and both the KA Ice Cream Mixers Parts List and Users Manuals in hand. If you're lacking them, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use 5KSM150, for you mixer and select the file 5KSM150PSEWH4.pdf (777.26 KB) listed under Parts List (1113) (you can actually choose any file sized 777.26 KB; they are all for the different color UK models) and then check to verify this matches your mixer model. This is a good file to have on hand if you ever decide to troubleshoot and fix your mixer by yourself.
After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List manual and then the Use & Care Guide (even if you don’t have a KA ice-cream maker) for your future reference.
If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
On the other hand, if your ice cream maker is not a KA model, you can still remove the collar, spring and groove pin if you’d like to give it a try. You will need a punch drive with a smaller diameter than the groove pin, a hammer, steady hands and plenty of patience. Tilt your mixer’s head up and rotate the planetary agitator shaft so that the flush end of the pin with the agitator shaft is facing you (the extended part of the pin is facing away from you). Align your punch drive on the end of the groove pin and give it a good whack; repeat until the pin starts to come out the other side of the agitator shaft. Continue tapping until the pin comes completely free. (Note the groves on the pin as you will need to orient the groove pin the same way when you reassemble the spring and collar on the agitator shaft when you’re finished making ice cream). Once the pin is removed the spring and collar will easily come off and then you can attempt to mount the ice cream maker drive on the agitator shaft. Caveat Emptor! Good luck, I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Testimonial: "Thank you for your swift reply and information, however I have since discovered that the US & UK machines are different and I can buy a UK converter."
SOURCE: I have a kitchenaid 5ksm150(UK), I recently purchased an
After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List and the Use & Care Guide manuals (even if you don’t have a KA ice-cream maker) for your future reference.
If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer's agitator shaft. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
