For some reason, it appears to have shut down from inactivity and will not come back online. we have had a service person out to look at it in the past but he said it was a power strip issue. We have unplugged and replugged with no luck. is there a reset button or something that I am missing to get this to reset and power back up?
SOURCE: Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
SOURCE: oki c9500 fuser
If you need replacement here you find some offers:
Okidata Fuser Unit 120 for C9300 C9500 ...
$189.72 - pcRUSH
OKI 41946101 Fuser Unit 120V ...
$160.83 - PROVANTAGE
Okidata C9300, C9500 Fuser Unit ...
SOURCE: OKI C9500
We had this issue and removing the optional hard disk fixed it for us, I'm guessing it was on the way out and wasn't really being used so it will not be missed.
SOURCE: Printer not communicating with computer
(1) Try a power cycle: Try turning the
printer off, then unplug the power supply from the printer, then unplug
the USB cable from the printer then the back of the computer; wait 30
second; then plug the USB cable back into the computer, then back into
the printer then plug the power supply back into the printer and turn
it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
SOURCE: I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
