F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
5. Buzz sound, chime or doors will lock and unlock should be heard at this point signaling that the vehicle is now in
programming mode. If not, wait 40 seconds and return to step 4.
6. All transmitters need to be programmed at this time, including the old ones. Push any button on the transmitter
two times. A buzz sound, chime or doors locking and unlocking should be heard at this point signaling that the
vehicle has accepted the new transmitter code. If there is only one transmitter, repeat this step two more times
using the only transmitter. If there are two transmitters, repeat this step two more times using the second
transmitter.
7. Push driver door frame button one time. Two buzz sounds, chimes or doors locking and unlocking 2 times should
be heard at this point signaling successful programming.
