Question about Apple iPhone 3G
I put in my sim card tray in backwards and now its stuck
I put in my sim card tray in backwards and now it is stuck can u help
  • jbmcgee48
    jbmcgee48 Apr 29, 2012
    same thing with me
    New Friend:
How to get the sim card tray out of my iPhone it is stuck backwards
Posted on Sep 11, 2015
Anonymous
SOURCE:
Alcatel one touch sim stuck in sealed phone, no tray just a slot next to the SD card holder. Can anyone please help me if they know how to get it out??
can you take a pic of the slot and how the sim card is stuck in there? Have you tried a small needle in there to see if you can catch the end of the sim card and then pull it out?
Jun 09, 2016 | Alcatel Cell Phones
Tip
How to replace iPhone SIM card
The only thing that you must have is a SIM eject tool or simply a straightened paper clip or any pin-like object hard enough to push-open the SIM tray. BTW, this SIM eject tool came with the box when you bought your iPhone.
Here are the steps:
First, refer to the image below to locate the SIM card tray. To pull it out, you need to insert the SIM eject tool (or the paper clip) on the tiny hole on the top of the iPhone 3G or on the right-side of the iPhone 4. Push until the tray pops out.
NOTE: The tiny hole found on the top of the iPhone 4 is not for the SIM card tray, it is a microprhone. Please do not insert any thing in there.
Once the tray pops out, pull it out completely and replace the SIM with any SIM you want.
When you're putting it back make sure that the SIM carrier logo is facing the front of the iPhone. Don't force it if it get stuck, just pull it out again, and gently put it back.
Here's an image for your reference:
Please read my other tips:
JAILBREAK
http://www.fixya.com/support/r5452955-jailbreak_all_idevices_iphone_4_3gs
UNLOCK
http://www.fixya.com/support/r5537989-unlock_iphone_4_3gs_3g_or_older_ios
on May 06, 2010 | Apple iPhone 3G
Tip
How to correct sim card error / insert sim card Procedure to follow Step 1:...
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Jan 19, 2010 | Cell Phones
How to fit sim card to ipad
Insert the tip of the SIM eject tool or a straightened paper clip into the hole of the SIM card tray on the side of the iPad.
Press the SIM eject tool or paper clip firmly into the hole until the SIM tray ejects.
Remove the SIM card from the tray, if necessary, and place the other SIM card in the tray.
Push the SIM card tray back into the iPad.
http://www.bing.com/videos/search?q=how+to+fit+sim+card+to+ipad&mid=C532A5A729B9058B83CAC532A5A729B9058B83CA&view=detail&FORM=VIRE6
video insert micro sim card into Ipad
hope this helps
Sep 17, 2012 | Apple Ipad 2 Wi-fi Black 16 Gb Pc Tablet
I have a nokia X6-00 and am trying to change my sim card. I have taken the battery off and opened the sim card cover, can slide the tab across so the sim card moves out but then it is stuck, I can't pull...
Please use gentle pressure to push or use a thin tool to slide the sim without damaging the SIM. Try and move it forward or backward so that there is free movement or the SIM is released from the jam position.
Mar 15, 2011 | Cell Phones
Sim card
Procedure to follow
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
Nokia 1110i says sim card not deteted even after sim card is inserted. Gives same message even after other simcards are inserted
It when your sim tray is been damaged thats when you experience problems like that.
Your sim card tray where you put your sim card is faulty,thats why your sim cards can not be accessed.
So you need to take it to a repairer to change the sim tray.
It needs to be changed
Jan 20, 2010 | Nokia 1100
How to put sim card to the iphone?
SIM card slot is in top of iPhone. From iPhone Manual:
If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
Install the SIM card:
1 Insert the end of the SIM eject tool into the hole on the SIM tray.
Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
Aug 11, 2009 | Apple iPhone Smartphone
The sim card tray in my iPhone is stuck! I NEED
Take it to your AT&T store and they will get it out for you, as if you break it you will get no cred, but if they break it, you will.
Apr 15, 2009 | Lands Phones
Apple iPhone 3G Logo
863 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
