Minolta Classic II Binocular Logo
Posted on Feb 20, 2010
The zoom lever is not working moves but doesnt change
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
22193
Points
58
If the zoom lever is not working then I would recommend buying a new pair without a zooming mechanism. Zoom binoculars are more trouble than they are worth. Sorry!
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
1helpful
Chevy cavalier gear shifter
if it is s manual box remove the gear lever tower from the top of the box and see what damage was done to the bottom of lever and/or lever pivot pin in the tower. Remember normal gear boxes require a gentle shift to allow the syncro rings to work properly and if you want to do racing changes get yourself a specially built box.
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Zoom is stuck
Zoom assy may be defective or problem with the lens. Try moving the zoom lever back and forth a few times. Sometimes, something in the lens will get stuck and it just takes a little repetition to get it "unstuck". If this does not work, you will have to have it repaired by an experienced technician. <a href="http://www.austintelstarservices.com">www.austintelstarservices.com</a>
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
1helpful
Zoom lever sticks
Hi, the only reason the zoom lever sticks is dirt. Either dust or some sort of liquid may have spilled on the camera. If you wipe it off, it does not help as the liquid gets into the zoom lever mechanism.It will have to strippd and cleaned.
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Zoom Won't Work
The motor has failed I guess Check the Olympus site for advice re repair or replacement.
Zoom Problem
Before assuming the camera is broken, have a flip through the settings menus to make sure you haven't got the camera into some mode which is incompatible with zoom - for instance, mine won't zoom if it's in SuperMacro mode. A.
Casio EXILIM ZOOM EX-Z850 Zoom button doesnt work
You have to send it in to repairs. You're lucky that the lens even still comes out.
Top Minolta Optics Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a Minolta Optic Expert? Answer questions, earn points and help others
