Question about LG 32LG30 32 in. LCD HDTV
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
A green line is appearing along the bottom of my hd lg TV, i have just had the sky hd box installed.
    New Friend:
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Posted on Aug 07, 2010
    New Friend:
Me too - had to switch hdmi resolution to 720 on sky box
Posted on Apr 05, 2010
  • Anonymous Apr 11, 2010
    found the answer in my tv onscreen menu under "special" - make sure the hdmi input is set to DTV and not PC
    New Friend:
Got the same problem in my LG TV but I have cable TV
Posted on Dec 18, 2016
  • Worship Freak
    Worship Freak Dec 18, 2016
    I think it's the TV. Other brands have the problem too
    New Friend:
I've got exaclty the same issue, 37" LG LCD TV, just had SkyHD installed and got green bar accriss bottom of screen. Any idea what it is?
Posted on Mar 14, 2010
6ya staff
SOURCE:
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Samsung tv 32:inch no LE32R74BDZ WILL NOT WORK WHEN CONECTED WITH HMDI CABLE ,SCREEN GOES GREEN. SO I USE COMPOSITE CABLES .I HAVE A FOXSAT HD SKY BOX. BUT I WANT HD PICTCURES. AS I HAVE AN HD BOX . IS IT...
We need to narrow things down . If you have a dvd player that has an HDMI output plug that into the HDMI input of the tv with a diffent cable than the one for the sky box. If color is still green then the main board on the tv is bad. If the picture is good then Either the cable used for the sky box is bad or the sky box is bad.
Mar 25, 2010 | Televison & Video
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Jan 15, 2009 | Televison & Video
Lg 37 inch lcd tv model 37lg3000
You may have got a bad unit but more likly it's your cable you are using I have found with the newer HD units the siganal has to be real clean coming in or you do get a distorted picture. Try changing out you cable lead for a good quality cable,
Nov 16, 2008 | LG 37LC7D 37 in. LCD HDTV
Green line problem
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Oct 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 32LG30 32 in. LCD HDTV Logo
2,705 people viewed this question
Ekse
RONALD CARTER JR
