The light on the left of my printer is constantly blinking. It doesn't matter what buttons i press, it won't stop and there is no paper jam.
this is how
to do it use xp
http://www.mediafire.com/?dbi16o3ovel1iyk
download
the v3400 for free in link above it is 9,5mb ( there is a other file dont use
it only the service mode tool v3400 )
follow this
instructions and you will be fine
http://www.2manuals.com/product_info.php?products_id=1445
- power OFF
the printer bu Power button. Dont disconnect power cable
- connect
the printer by USB cable to the PC.
- press and
hold Resume button (red triangle in the red circle) and press Power button
- hold both
buttons until power on indicator will light then release resume button (dont
release Power button) and press Resume button 5 times
- release
all buttons - the printer will blink few times with green light and will then
light green constantly. You have put the printer in Service Mode now and you
can now run the Service Tool. (If the printer is still blinking by green - you
have some other errors in printer and you have to fix them first, because the
Service Tool will not work if the printer is not put in service mode - green
light is constant)
4. Run the
Servicetools V3400.exe program.
5. Select
the connected USB port number from USB PORT
6. In the
Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber
pull-down menu.
7. From the
Counter Value(%) pull-down menu, select the value (in 10% increments) which is
the closest to the actual counter value confirmed before replacement of the
logic board, and click SET.
Print EEPROM
information to confirm that the value is properly set to the EEPROM
hi caveman 68
this is how to do it use xp
download the v3400 for free in link above it is 9,5mb ( there is a other file dont use it only the service mode tool v3400 )
follow this instructions and you will be fine
- power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
4. Run the Servicetools V3400.exe program.
5. Select the connected USB port number from USB PORT
6. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
7. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
If by the light on the left you mean the one one above the box with a tear drop in it, this means you have an issue with the ink cartridge. Please check the ink cartridges have ink and are correctly installed. Please clarify
