Your model refrigerator uses an electronic Ice Maker. You can test the Ice Maker by filling with tap water and let freeze sometimes they already have ice inside and shrinking because of defrost. If you can fill the trays with tap water and it freezes and dumps but does not refill with water the problem will be the water control valve. If ice maker does nothing and on then the Ice Maker is the problem. Try that first and let me know what you find, Sea Breeze
Your replacement Ice maker is part number Click Here=> WR30X10093 and the water control valve is part number=> WR57X10032 I hope it is only the dual water control valve but knowing the electronic ice makers it would not surprise me.
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
SOURCE: ice maker problem
let it run its caused by stagment water in the system it will clear over time.
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
SOURCE: Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
SOURCE: water will not flow into ice maker
This could be 2 reasons for this The water control valve on back for the ice maker is defective or the thermostat inside the ice maker is defective. You can pore water into an empty ice maker and let it freeze. If it cycles and does not refill with water I would say that the water control valve is defective. Your refrigerator has 2 dual water control valves one is for the water filter assembly the one on the back is part number 61005626
Let me know what you find, Thanks sea Breeze click link below and enter model or part number in search feature.
http://servicepartstec.blogspot.com/
