I have a Hamilton Beach Water Cooler Model 2312C, Type WD01, Series A3650CT. The hot water dispenser has suddenly stopped heating the water. I have tried turning the hot water button on the back of the machine on and off and nothing helped. How can I fix this? Does it need a new heating element?
Also, where can I get the manual for this? I bought it secondhand.
THANKS!!
Problem: Water is not hot Possible Causes: Dispenser is unplugged Solution: Push plug completely into outlet Possible Causes: Heating switch not on Solution: Check to be sure heating switch is turned to ON Possible Causes: The fuse is blown/circuit Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker. 2. If too many items are plugged into a single circuit, move some items to a different circuit Possible Causes: Temperature limiter tripped Solution: 1. Set the hot and cold power switches to OFF position. 2. Wait five minutes, then set switches to ON position. 3. Wait 30 minutes for water to heat or cool Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
