Toshiba Satellite L25-S119 Notebook Logo
Anonymous Posted on Feb 18, 2010
Toshiba Satellite L25-S119 laptop-No image on screen but the fan powers up when the power is turned on. The Power button illuminates then turns off but the fan continues to run.
  • Anonymous Feb 19, 2010
    Yes the hard drive light comes on as well as all of the other lights showing that the computer is powered up. Additionally, I've also tried connecting it to an external monitor....that was actually the first thing I did but there was no image being displayed from the laptop to the external monitor either. :(
phoenix kirkham
Level 3:
  • Master 641 Answers
  • Posted on Feb 18, 2010
phoenix kirkham
Master
Level 3:
Answers
641
Questions
Helped
112322
Points
1352
Well your leaving a lot to the imagination..is the hard drive light working..plug it into a external monitor then boot it..then we can go from there..
  • phoenix kirkham
    phoenix kirkham Feb 19, 2010
    ok well thenn..did you use the function key and the F5 and F6 keys to change back and fourth from screen to external..
My toshiba satellite l25-s119 turns on but the screen is blank?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
I have the satellite L25-S119 and it will not power on with the battery or the powercord. What can I do?
If you can find someone with a multimeter you can test the power supply... If there is no reading then its dead.
Take the battery out then check if it powers on.
If the above didnt help you may need to take it to a laptop repair place.
Dont worry too much your pictures & documents should be safe 9/10
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
2helpful
Toshiba Laptop L25-s119 will not work under household power.
Is this a new laptop ?
Your battery may need replacement!
I changed the hard drive in my toshiba satellite L25 now it will not power on
Did you take out the battery when you changed the hard drive. It still has power in the circuits when the battery is in. You might have fried it. I would try taking out the battery and push the power button a few times (to discharge any power in the board) then make sure the hard drive is inserted properly. Good luck.
My Toshiba Satellite won't turn on at all
If no lights/nothing happens when you press the power button then you probably have a corroded power socket on your motherboard, the positive terminal will not be connecting properly to the motherboard. The laptop needs to be dismantled and have the socket resoldered properly. This can cost quite a bit at most places. I would check the charger first to make sure it is not the problem.
Toshiba Satellite L25-S119 Laptop will not power on
You more than likely have damage to the motherboard. If it's still under warranty they will probably clasifiy this as abuse, and charge you for the repair.
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
1helpful
My toshiba satellite A200 series wont start up.when i switch the power on it just lights up.but nothing follows.
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
