SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
