Question about Kenmore Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Kenmore refrig/freezer. freezer side is cold, icebox is cool to warm. comp compartment cleaned & vacuumed.comp & fan works. thermostat for refrig. works(turns icebox side on and off), i'm guessing thermostat but?
    Sergeant:
  • 256 Answers
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Posted on Feb 17, 2010
Testimonial: "coils already been cleaned, will check defroster/ thermostat. thanks"
Anonymous
SOURCE:
Emerson CR500: freezer is cold; refrig is not
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost system problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Aug 24, 2014 | Emerson Cr500 Refrigerators & Freezers
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
A side by side kenmore coldspot the freeze is getting cold the refrigator side is very warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
New Kennmore side by side freezer works but refrig is warm
Do you hear the fan running in the back of the compartments when either door is open? The freezer side runs the fridge side and a fan transfers the cold air from the freezer to the fridge side. If the fan does not run or there is a blockage then the fridge side will not get cold of course.
Sep 29, 2009 | Kenmore Refrigerators
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kennmore Cold spot Model # 57285791. The center strip where the two doors meet is extremely hot and everything in the freezer is defrosted.
2 things you neeed to check first of all clean teh coils underneath the refrig. then pull unit from wall and pull off rear compartment cover and see if the fan that cools compressor is running. it is possible the motor is jammed or bad. if the motor is bad you can put a house fan blowing into the comp compartment until you get it repaired.
Jan 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
169 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
