"PROTECT" shows on display and unit then clicks and switches off on my DENON DHT-500SD home theatre system
SOURCE: Protect error
This is a failure of the power supply or the amp. In either case, this unit is one that the boards are available and should be replaced. The first thing you must determain is which board is bad.
I have been repairing these since they started making them, and can tell you that it is not an easy task to figure out which board is bad. You will need a multimeter, and then know how to use it very well.
Sometimes you can get pointed in the right direction just by knowing what was happening when it went bad.
If the unit was working and you turned it off, then the next time you went to turn it on you started getting the "protect" message in the display, you most likely have a bad power supply board.
If you were listening to the system and it just shut off on you and then when you turned it back on you got the "protect" message, then it is most likely the amplifier board.
There is one more thing to check before you ever buy a board for this unit. If the fan in the back is not turning when you turn the unit on, it may only need a new fan. Lets hope that this is your problem, it is cheap and easy to fix. The other options may be better for you to take it to a service center to properly troubleshoot The boards are a little expensive, but that is what Samsung does with these units, they replace the boards. Most all other audio equipment from all other brands do not even make the boards available.
Check the fan first, if you need the part number let me know, I think I may have a manual to look it up for you. If you want to try and check the boards, I may be able to help a little more, but this is a very difficult thing to do over the internet.
I would appreciate it if you would wait until we are finsihed communicating on this problem before you rate it.
Thanks,
Dave
SOURCE: dht-5oosd home theatre system
I thought it was a free service in which case I would have been happy to inform you how I had solved the problem. However, as you wish to know to enhance your own skills and then charge for the service, especially one which I have aided in, I am left astounded at your ordasity
SOURCE: Denon DHT-500SD - DVDs wont load
the problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
