In general more info is required, but most likely this is an issue with your display settings. Try the following:
1) Try pressing the Fn and Display buttons (at the same time) on your laptop. Try it once, twice, and then a 3rd time.
Chances are that your laptop is displaying in a resolution that is not completely compatible with your monitor, so when the display settings are switched from laptop LCD and montor, to monitor only, the resolution should adjust automatically.
2) If that doesn't help you, try lowering or adjusting the resolution on your laptop. If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust it. If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know what happens!
