How can I turn off the beep sound on my exxcel washer/dryer bosch machine
I've just found my instruction manual and managed to turn the volume off on mine after 6 months of annoying beeping.
You turn the programme selector to off then turn it one programme to the right, press the rpm button and keep it pressed while turning one more programme to the right, release them both and a number should be displayed on screen I think volume 2 is the default one. You then click the "ready in" button until desired volume is reached. You have a chioce of zero through to four. After volume is set turn programme selector to off position. The annoying beep should be no more!! Hope this helps others.
Brilliant advice. You'd think it would be in the manual or clear on their websites. essie361 = A1* Cheers
You turn the programme selector to off then turn it one programme to the right, press the rpm button and keep it pressed while turning two more programme to the right, release them both and a number should be displayed on screen I think volume 2 is the default one. You then click the "ready in" button until desired volume is reached. You have a chioce of zero through to four. After volume is set turn programme selector to off position. The annoying beep should be no more!! Hope this helps others.
(This is an amendment to my first post, the amendment is marked in bold).
Just bought Bosch washing machine last night!! Have done two loads this morning and the BEEP noise is driving me nuts!! SO - I followed essie361 instructions on how to stop the BEEP!! AND pronto "IT WORKS AT TREAT" . Instruction booklet on this problem is very complecated!! Thank's again essie361!!
Excellent solution - I've put up with confounded annoying noise for a few years but now, NO MORE!! I can put up with the nagging of my wife and two daughters, but not with the nagging of a stinking washing machine. Who on earth would want this function anyway??
I had a BOSCH engineer out to day because this stupid washer/dryer is hopeless at spinning anything remotely bulky and while he was here I asked him to turn the beep off. He showed me how to do it, it said OFF and I hoped it was sorted. Turned the machine on and would you believe it's beeping still. I have remembered how to turn it off but for some reason it doesn't seem to stick in the memory. Would appreciate any advice as to how I can turn it off for good as it's driving me nuts!
