My projector starts up several times before the power light turns red and the temp light blinks red. I have checked the cleaned the air filter, but I still can't get it to come on. Any suggestions?
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
Goodluck..
Please rate my solution i have given you the right answer.
please accept my solution as fixya.I have given you the right answer
Did you read my post i told you to replace the lamp. if it is not possible for you to do that then you have to give it to the service center.To know how to change the lamp please read THIS
And regarding the fan i have also told that in my above post.
Click HERE for the user guide.
If you are satisfied with my solution then please don't forget to rate it or accept it.
Caring for the air filter
The air
filter should be cleaned about every 100 hours. If the LAMP indicator
and TEMP indicator blink red simultaneously, or a message prompts you
to clean the air filter when you turn on the unit, the filter needs to
be cleaned.
1 Turn off the projector, and unplug the power cord
2 Apply a vacuum cleaner to the top of the air filter cover to clean the air filter
3 Turn on the projector, and use the menu to reset the filter timer
4 Reset FILTER TIME [Use this function only when the filter is cleaned or replaced!]:
Depress the RESET button for at least 3 seconds while filter time
is being displayed. The reset menu will then appear. After you replace
the filter, select RESET on the menu with the button.
�Do not reset the filter time unless you have cleaned or replaced
the filter. And, always reset the filter time when cleaning or
replacing the filter. The message functions will not operate properly
if the filter time is not reset correctly.
Alright you can rate Johnychel's solution as thanx for trying.Or if there is nothing like that you can ignore his solution,i mean just select the option other than accept in johychel's post he will then be rated as thanx for trying and then you can rate me.
Can you tell me what are the two options given at the bottom of Johnychel's solution?
Please send an email to [email protected] regarding this issue they will fix it.
Thank you for using fixya..
I already fixed this. You must replaced the Bulb set.
How do you service the projector?
I don't know how to do that. The power light is solid red, the temp light is blinking red, the lamp light is off.
I meant I don't know how to rate your answer. I'm not given the choice of accepting your answer.
I don't mean to sound stupid, but I can't rate his answer either. This is my 1st day on this website.
His "solution" is in a green box and your solution is directly under it. There is nothing for me to choose. I don't even know how his answer got rated because it didn't help. Like I said, I'm new to this website today.
expertbullet I replaced the lamp and still have a red lamp indicator. What should I do now?
The projection is VERY dim. Like so dim I can't see anything. Also the heat and temp lights are flashing red. The lamp was just replaced about four months ago. I use about four hours a day, what could be the problem?
