I am looking for repair manual for Bosch Washing Machine WFLI2440
I am looking for repair manual for Bosch WFLI2440GB as need to replace the heating element.
Liz
    Sergeant:
  • 215 Answers
Hi Liz, dont think you will find manual for that make or model. But if you have Halfords store near you they sell Haynes manual for washing machine repairs, which will give you very good idea how to do this. most machines are about the same when it comes to this. If this is any help to you remove plug, if you can access heater make note of all wire positions and remove them. remove small nut in centre of element and pull back plate. now you should be able to push the threaded piece forward a little. element should now come out. when replacing use washing up liquid to help get grommet onto tub. also remember to replace the nut and tighten up as this forms the grommet to make the seal. good luck
Posted on Feb 12, 2010
6ya staff
SOURCE:
My Bosch Vision 300 series washing machine wont start?Why? What has to be done to it?
Michael, the door lock/latch mechanism should be tested, if faulty replace. Have a good repair Tech. check, diagnose and estimate repair. Make sure to at least look at the first link, it tells of a reset procedure that may fix your washers door latch problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://baubilt.com/?p=1318
How to replace washing machine door lock on Balay Bosch Neff and Siemens
http://www.repairclinic.com/Shop-For-Parts/a11b129/Bosch-Washing-Machine-Parts
Aug 22, 2016 | Bosch Washing Machines
Bosch WFLI2440GB/5 Washing Machine drain pump running continuously
Bosch WFLI2440GB/5 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 08, 2011 | Washing Machines
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Hello i would like to replace door interlock on my WFLI2440 GB/18 bosch washing machine , having problems tacking the old one out. can you help.thanks.
hello start by taking of the metal band on the front of the machine there may be a clip that holds the band on unclip it the band should come off peel back the rubber off the door you should see the interlock undo the 2 screw the are over the hole the interlock should come off in your hands there will be wires connected by a clip unclip it thats it hope it helps
regards
shaun
Apr 24, 2011 | Bosch Washing Machines
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
No water in Bosch WFLI2440GB/05
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Fitting washing machine boot gasket/door seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
May 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wont spin
go back inside it and look at the place where the drive connects to the drum is there anything loose or missing that should be attached the drive coupling breaks or comes loose, i dont know about this particular model if its a belt driven or what but look closely at the connection to the drum and see if anything is abviously loose or broken.
Dec 20, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Tub Seal needs to be replaced
Aug 31, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
292 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
