When I choose a cycle and press the start button, the dryer makes the usual click noise. After that though, it beeps a few times and doesn't start the cycle.
I started it and left it on, it goes through the sensing steps of the cycle but it does not spin. I have already checked the belts and they are intact.
Does anyone have any idea what the problem is?
thank you,
SOURCE: Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
SOURCE: Duet Dryer will not start, Press control on, Start, then it beeps
try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
you have a blown thermal fuse. you can get one where they have parts it is about 5 dollars.
SOURCE: Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
SOURCE: Dryer won't start cycle. Sensing light turns on and it beeps then
Unplug the unit and take the back off. Down towards the bottom, near the exhaust connection, you will find a small, white thin plastic part with 2 blue wires connected to it. Remove the wires, put them together, wrap with electrical tape, and then plug the dryer in and see if it runs then
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
