As per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since
its a cordless phone ,or your phone is not getting a complete
connection, could be one cause,Please try these solutions when you
experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2)
Press ^/vol or vol/v to move the pointer to Clarity Boost, and then
select Boost On and "B" appears on the display. To turn Off the Clarity
Booster, repeat above step again. check the owners manual for a full
description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3.
Make a phone call & at the initial stage speak loudly into the mic.
Please note: The ECC will learn at the initial stage only, so after
these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh
registratoin, this can improve the quality of the call. hope this helps
pls do let me know"
