I bought a Toyota Camry with an Audiovox Pursuit Pro 2032. Everything was working fine until I had to replace mt battery. Now my keyfobs unlock the doors but the alarm sounds whenever I try to start the car. These are the original keys. The car is currently in valet mode until I get these reprogrammed.
If thats the picture of the transmitter to program it you have to : turn the ignition to on position. press and release the programming switch 3 times... press and hold,for 3 seconds, the buttonof the transu wish to add until the parking lights flash. this would mean the transmitter has been learned. repeat step 3 for each transmitter... turn the ignition off to exit the program mode..
do not let 15 seconds pass between steps.
If
the remote s faulty then key fob will not get programmed.
Insert
the key in ignition. Turn the key to on position, and cycle the key three times
off-on-off-on-off-on. Then with the key fob remote select your remote and then
try to operate the vehicle with remote.
These
are just the basic procedure, but sometimes it will not help.
On
that case dealer is the only option.
There
are few much related troubleshooting links mentioned below for remote key fob reprogramming.
I suggest you to go through the list and click the link below to go through its
details and procedure: -------
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These
details will help.
Thanks.
KEYFOB PROGRAMMING
If
Insert
These
On
There
These
details will help.
Thanks.
----------After getting car
washed, check engine light is ON and key less entry not working, tried
reprogramming. Also car shows fuel pressure?
-----------Audi A8 Key Fob Programming?
Oldsmobile Aurora Key Fob Reprogramming?
Buick Lesabre Key Fob Reprogramming?
Keyfob remote not working on 2003 Ford E350 Econoline?
KeyFob will open the doors but not start on BMW?
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not
Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not
release?
These details will help.Thanks.
I changed the battery on my car and the pursuit car security auto start wont work now. 2010 CRV Honda
