Question about JVC LT42P789 42 in. LCD TV
I have suddenly got a gray panel on the right hand side of the JVC TV screen saying E4 HDMI 1 1080i How do I get rid of it? Alan
  • JVC Master
  • 8,457 Answers
U have a reminder.It show up because u press MENU button to show up.Press menu agian well disappear.
Posted on Feb 10, 2010
6ya staff
SOURCE:
I touched the wrong button on the remote and know tv says no signal and I can't get it back
Try going to your input button on your remote and see if you are still on the right input like if your tv is using a hdmi cable from your cable or satellite box then your input should be hdmi or hdmi 1 or hdmi 2 etc... also if you have cable or satellite make sure you didn't change the actual tv off of channel 3 or 4 whichever you have your cable or satellite box set on. I hope this helps.
Feb 06, 2016 | Televison & Video
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
I didnt have a picture so i started hitting buttons. Now I have HDMI Settings with two options showing and can'get rid of it
Have you tried using the "Menu" button or "Input" button on the left-hand side of the set to make a selection/change the current selection?
You may also want to try unplugging the set for at least 30 seconds to see if removing power will clear the frozen screen.
Finally, note that three of the four HDMI inputs have notes associated with them in the manual on page 3, the "Part Names" page. See the notes on the right-hand, bottom of the page; items 3, 4, and 5.
Dec 31, 2014 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
How do i get rid of the blue box on my tv screen without a remote? Its from the picture inside the picture.
Normally there are controls for tv on rear to 1 side of tv , different sides for different makes, LG is on right hand side when looking at the screen.
Nov 29, 2014 | Televison & Video
Hook up netflix
Get a Roku streamer. It had an HDMI out as well as a composite cable so it will even work on older tv's You'll need to have a fast internet connection and a wireless capable router.
Dec 30, 2013 | JVC Televison & Video
I have a JVC tv, model number AV-29RS and i have this problem that there is the channel number that comes up on the top right hand side of the screen in a gray box and wont go away. The only way i can get...
this happens as the wrong code on the remote control is ther
cab you reset it and authomatically change it into another code
try other code Phylips may do as Itt also
try and buy another remote comtrol as sometimes other works better as it seems your is getting stuck
Sep 27, 2009 | Televison & Video
Git rid of display on screen
Hi There,
Can you access the Menu List from your front panel?
Mar 29, 2009 | JVC AV-32D305 32" TV
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Gray spots on screen on a JVC HDILA model HD 56G 787
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC LT42P789 42 in. LCD TV Logo
191 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
