Dryers Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i find a model number. It says Senseon on the front door
Anonymous
Level 2:
Novelist:
  • Expert 108 Answers
  • Posted on Feb 10, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
108
Questions
0
Helped
43542
Points
345
Usually the model and serial number are on a sticker inside the dryer door.
Whirlpool Senseon dryer model GEW9868KQ1 has E7 error code.
Question edited for clarity.
This is the technician repair sheet. Are you sure it is E7 and not E1?
https://www.applianceblog.com/mainforums/attachments/gew9868kq0-tech-sheet-pdf.17906/
I have done multiple searches for E7 and found nothing.
https://www.google.com/search?q=Whirlpool+Senseon+dryer+model+GEW9868KQ1+has+E7+error
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
I have a Whirlpool Gold senseon Model number GeX9868Jq1 I can feel the heat inside to Dromm but when I push start it just clicks It's a electric dryer
Unfortunately, it sounds like the motor, since you aren't hearing it run. Motor turns the drum by way of a belt.If motor is running, but drum not turning, it would be the belt... I would also say door switch, but then the heating element wouldnt be heating up. Slight chance it could be the control, but I doubt it. DW
May 12, 2014 • Dryers
Whirlpool Senseon dryer control panel won't work
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
In diagnostic mode, my Whirlpool senseon dryer displays 79 insstead of 88. What does this error code mean?
Idon't know the answer to this, but could you please tell me how to get into diagnostic mode on a senseon?
Where do I find the serial number/ model number on my front loader?
If this is a Kenmore front loader, the serial number is on a nameplate tag around the door opening along with the model number. You need to open the door to see it. I hope this helps you.
1helpful
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
