Question about Generac 5622 GP Series GP5000 6,250 Watt 389cc OHV Portable Gas Powered Gen
Gererator turns off when i turn the idle control switch on generac 7500
  • 25 Answers
The governor or or the idle coil assy needs to be replaced. Possible that a adjustment could be made.
Posted on Feb 11, 2010
6ya staff
SOURCE:
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
It back fires
If it backfires, check for manifold leaks, fuel mixture is too lean, timing is off, make sure it isn't spitting liquid into the cylinders and the LP is the right pressure, and the vapour coil is working
Oct 05, 2013 | Generac Guardian RV Generac RV Generator -...
How do i turn up my idol on my 1998 s10 blazer its running at about 5500rpm and i believe it should be running at 7500 or so
You can`t turn your idle up.It is all controlled by the computer.You should clean the throttle body and idle air control seat.Make sure the egr valve is not sticking.Might have to perform an idle learn procedure.This can only be done with a scan tool.Hope this helps.Good luck.
Dec 18, 2009 | 2003 Chevrolet S-10
Generac 4000xl high idle, idle control not working.
check to see if somthing is blocking the movement of the govenor linkage
Oct 26, 2009 | Electrical Supplies
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Jun 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Generac 5622 GP Series GP5000 6,250 Watt 389cc OHV Portable Gas Powered Gen Logo
363 people viewed this question
Top Generac Measuring Tools & Sensors Experts
deton8 von Splosion
Joseph Mueller
Joseph Mueller
Starlight Power
Starlight Power
Are you a Generac Measuring Tool and Sensor Expert? Answer questions, earn points and help others
