Tv Turns On with blue screen and says no signal and then turns off automatically after 15 seconds. I am unable to change inputs using the remote or the controls on the TV. It will not got to the menu. I am stuck. I checked 3 times and all of the components are hooked up correctly
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
If
your television is displaying a blue screen or no signal message and
then turning off, your TV may be at an inactive input. Here's how you
can get back to watching your TV: 1. Powering on your
TV and press the INPUT button on the VIZIO remote control repeatedly
until a picture re-appears. 2. If this does not work, try again but press the button slower this time.
This sounds as if when the dog rolled on your remote he has pressed the source button so that you are no longer on the TV cahnnel. The TV is looking for a different input eg. AV1/AV2/HDMI etc. This will give you a blue screen & as there is no signal the TV will switch off. Check on the remote for an Input or TV/AV or source button & make sure this is set for the TV signal.
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Just hold down the input button on the right side of the tv. This is the bottom one. So, With the tv off, press and hold the bottom button (input) when the tv turns on, and you see the input menu release and press the button to put the tv into a mode that works! Thanks
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
