Hi there!
im stock here with a big problem. i forgot my lock code for my nokia n80. is there someone who could help me out pls? IMEI is 358814/00/274011/8 pls pls
Hi if the phone is asking for the code when you swtich it on then i can help you with master code but this code only works if its asking for code as soon as you switch on and will also only work if you havent entered the code wrong more than 5 times if it has been wrong more than 5 times then it can only be unlocked using flash lead and unlocking software let me know then i can assist you further ok
help plzzzz!! i hv n80 n hving same 'lock code' prob, forgot code. want ph internal code "lock code" not the sim or network unlocking code. right now its full functional but as i try to format ph using *#7370# or try to change som spl settings it asks for 'lock code'. i knw the factory code 12345, even tried 11111 and hv network puk code aswel. further, i formated ph using 3 keys method cal key+star+3 with power key, it restord all settings expect that ***** "lock code". Pls help!! further more i hv usb (data) cable aswel, if som1 hav any type of pc unlocking software?
thanks n rgds
[email protected]
