Have the cooling system pressure tested, that will tell you for sure if system is leaking. Have you changed thermostat? Might be sticking and making it run hot. Water pump front seal could be leaking, when pressure testing look to see if coolant is leaking around front water pump seal if not check elsewhere for leaks.
This is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
Our 2007 dodge charger is leaking anitfreeze. what could it be? we changed water pump and thermostat and it is still leaking.
